List folder error reporting
Is it possible to turn off List Folder error reporting?
Jim Haas
(3,285 Views)
Hi JHaas,
which errors do you get?
Do you do some error handling of the "error out" wire coming from ListFolder?
Hint: how to avoid unexpected error messages is part of the CLAD certification. To solve the CLAD test you should take the Core1&2 courses. Did you?
(3,278 Views)
I have no idea.  I just clear errors if I am not interested in them.  (Although the 43 user cancelled error on a file dialog box gives me pain, even though I can make a weak case for the existence of said error.)
I don't even know if it's possible to disable error reporting on any node...
Bill
CLD
(Mid-Level minion.)
(3,271 Views)
