List network interfaces via .net
I try to list the available network adapters over the .net class "NetworkInterface" found in "System.Net.NetworkInformation.NetworkInterface" but the constructor therefore is not available... (see attachment).
I not have a clue what's my mistake here...
Message 1 of 8
(6,921 Views)
Accepted by topic author DonBorste
It may only contain static methods and therefore has no constructor. Try to place a property node or method node on the diagram and then select from there for this class and you would see all static methods (or attributes) then.
Rolf Kalbermatter  My Blog
Message 2 of 8
(6,880 Views)
Here is a way to do it,
I used this link and followed the c# example.
Rolf is right, it has no constructor since its static method.
Martin
Message 3 of 8
(6,870 Views)
You still should close every .Net refnum returned in the array after use.
Message 4 of 8
(6,852 Views)
Hi Rolf,
thanks a lot, pretty simple 🙂
Message 5 of 8
(6,833 Views)
While I search the internet for the same question (well, similar question), I found this forum post. Which I liked but I also got another search result:
https://learn-cf.ni.com/teach/riodevguide/code/rt_show-available-ip-addresses.html
I found this other solution to be more straightforward to get a list of all IP address (which is what I was aiming for).
So, if you only need all your IP address, you can use the String to IP VI, you can right-click on it to enable multiple output. This will output an array with all your system's IP.
Anyway, since I hit this forum post first while searching, I figured I'd update it for others that might find this post.
Vincent Carpentier, CLA, CPI
Neosoft Technologies/PVI Systems
NI Gold SI Partner in Canada and the US
www.neosoft.ca
www.pvisys.com
DQMH Trusted Advisor
Message 6 of 8
(5,789 Views)
I'm guessing there was a reason the OP needed to do it through .NET - although, for the life of me, I can't imagine why.  Maybe the OP had no idea how to do it with native LV code, and no one picked up on that...
Bill
CLD
(Mid-Level minion.)
Message 7 of 8
(5,770 Views)
This .net method works only for connected interfaces.
How to get all connections including those currently not connected interfaces?
I want to present a list of all connections for user to select.
George Zou
Message 8 of 8
(5,433 Views)
