ListBox-Limited number of selected items.
Dear Sir or Madam,
I would appreciate any comment or suggestion on the following question.
How I can limit the number of items selected in a ListBox?
Assume that you have 3 items but I want to have 1 or 2 selected items
but no more.
The selection mode: (0 or more) or (1 or more) does not work for me in
this case.
Thanks in advance for your Help.
Luis Diaz-Ballote.
luis_diaz_ballote@hotmail.com
(2,768 Views)
Hi Luis
I have done something similar, except I used the tick symbol to indicate
that the item has been selected and used '0 or 1' selection mode.
The steps would be:
- check if the listbox value
- if the value has changes or >-1 and there is no tick there then put a
tick
- if the value has changes or >-1 and there is a tick there then put
remove the tick
I hope this alternative helps
Tim
Luis Diaz wrote:
> Dear Sir or Madam,
> but no more.
> this case.
> Thanks
> Luis Diaz-Ballote.
(2,768 Views)
