ListBox (No active items)
Hi everybody, Could any of you tell me if I can set to "no active" an item
from a multiple selection listbox under some conditions? Perhaps using atribute
node facilities? I haven't been able to find the way. Yhanks.
(3,317 Views)
Set an emty numeric array on the Multible selction box
E
Click here for Free Video!!
http://www.gohip.com/freevideo/
Eduard Muñiz wrote in message
news:38f420f9@newsgroups.ni.com...
item
atribute
(3,317 Views)
I think you're after a way to disable individual choices from a multiple selection
listbox. If that's correct, then I'm not aware of an elegant solution. What you
could do is add a structure to your monitoring loop that programmatically deselects
certain choices, depending on other logic in the diagram (or some variation of this
idea elsewhere in the diagram).
If you are asking how to deselect all elements of a listbox, then you can just
create a local variable for the listbox and wire in an empty array.
John Lum
(3,317 Views)
