Listbox Symbol Ring Constant error?
Hello Folks,
Today I've used the Listbox Symbol Ring Constant and it seems to me there is an error in it.
If you compare it with the popup list from the Tree Control (when you want to set a symbol) I've found that items 39 and 40 - the greyed-out checkmark box items - are swapped in the Listbox Symbol Ring Constant.
When you choose item #39 it should be,  like the Tree Control, a grey box with a checkmark. In stead it is a empty grey box. When you choose item #40 it works just the opposite.
Can anyone reproduce this?
w.k.rg.
Hennie Blanke
The Netherlands
(2,924 Views)
It's a known issue. See here.
___________________
Try to take over the world!
(2,917 Views)
