Listbox problem
I want to have a list with system checkbox in front of each cell. There is just one column wih values. By checking the boxes, the values in the column are selected. And the list should be editable.
How can I do that?
Thanks alot for any help
Yves
(4,773 Views)
Here's one way of doing it.   Not necessarily the most elegant. 🙂
Eric
(4,742 Views)
One more way to do it Smiley Wink
Dev
(4,734 Views)
Thanks for your help.
Both example are almost what I needed.
But isn't it possible to have the checkbox in the table / list? With this it would be possible to select a bigger number of cells. And the vertical scrollbar would become very useful.
Yves
(4,727 Views)
with your help I found a good solution. Maybe anybody else can use this.
Enjoy your weekend Smiley Wink
Yves
Using: WinXP, LV8.0.1, LV 8.2, NI-SAV
(4,713 Views)
Good Work!
   I also discovered that Labview 8.2 has a "radio button" control, which allows you to have MUTUALLY EXCLUSIVE selections, if that's what you need.  I'm certainly glad they have the radio button now, because I once had to figure out how to do that 'longhand", and I've since forgotten how I did it. (Hint...it was NOT a trivial problem!)
   Anyway, with the radio button, you can pipe the output to a case structure, and put each of your selections in a new case.   Actually, I really like this problem, because there are so many divergent approaches to solving it.  Really gets the old brain follicles going!
eric
(4,706 Views)
