Live update of a graph modified in a subVI
A quick explanation of the situation:
I have a program allowing to acquire data from a CCD camera.
This program acts as standalone or as a TCP server for another software piece.
 I would like to write the TCP server part as a subVI, returning, say, the "CCD-Image" object.
Everything works properly now, expect that while in TCP server modus the image is returned only when the subvi is terminated.
I would like to get the "CCD-Image" object updated as soon as it is modified within the subVI, is this possible?
This is pretty similar to creating a local variable, but to place it in a subVI rather than within the VI where the original Object is.
Thank you for your help!
Mat'
(3,022 Views)
Hi Mat',
the TCP server should run parallel to the other code. It sounds like there is something with the data flow.
Can you show your sub vi and the overview who calls it?
Mike
(3,016 Views)
Accepted by topic author MathieuG
Thank you for your reply!
I actually got my information from this post, which I first did not see:
http://forums.ni.com/ni/board/message?board.id=170&message.id=264805&query.id=107551#M264805
Mat'
(3,006 Views)
Hi Mat',
sorry for not understanding it, is it solved now?
Mike
(2,993 Views)
Yes everything solved, thank you! 😉
My question was not as clear as it should have been!
(2,985 Views)
