Load Warning Summary : ActiveX Typelib mismatch detected
What does this message really mean?
Do I have a mismatch in my ActiveX control between the .idl and the .rgs files ?
(3,230 Views)
Hello Rastikan,  I am not sure why you are getting this warning.  The good news is that as a warning, there is a good chance that it will not cause any problems with your program execution.  Have you always gotten this error when loading your program?  Does your application still behave the way you expect?  What ActiveX control are you using?  Thanks.
(3,186 Views)
