Load measuring codiing
Greetings. I can't open attached LabVIEW files. I got it from one of my friend. Can any one help me by mentioning the reason of blocking and its solution?
Thanks in advance.
(3,468 Views)
Hi Milon,
after renaming the files to use plain English names (no UNICODE!) LabVIEW can open them easily.
They are made using LabVIEW2010…
Tell your friend to use only English file names!
(3,464 Views)
Hi GerdW,
Thanks for quick reply. I tried but can't. Picture attached.
TIA
(3,438 Views)
Hi GerdW,
TIA
(3,437 Views)
after unzipping I could rename all files using the default Windows Explorer: select the file, press F2...
(3,425 Views)
Hi Milon,
Try copying and pasting the files to a separate folder and renaming before opening them there. Works fine here on Windows 10, see attachment. The Labview version difference shouldn't prevent you renaming these files but may be an issue opening them.
Tony
(3,359 Views)
