Load resource error
I have a program which has some CVI modules(used as DLL in labview), I built a installer using Labvuiew Runtime 8.2 and CVI 8.0.1 run time,.
I installed the application but when i try to run the application, I get resource error for all the SubVI where i have used CVI modules, CVI DLL was built using CVI 6.0
have attached screen shots, the modules are sub-vi's, so I dont need front panel included.
My installer installs 10 modules during installation along with CVIRTE, but after complete installation I don't see any CVI module in C:program files:national instruments:shared:product cache.
I am having a tough time,
Thanks in advance.
(3,504 Views)
Accepted by topic author cancancanopen
Found solution, Thanks for the MAX, I installed MAX on the machines where it gave resource error and found that even though I installed CVI 8.0.1 the system had CVI 9.0.1, CVIRTE.DLL ver 8.0.1 was not replacing earlier CVI 9.0.1 version,
So i deleted the CVIRTE.dll from System32 folder and then re-installed my program and it started working fine.
(3,456 Views)
Thanks man
(3,433 Views)
