Load the front panel of nested Actor into Root Actor front panel
i would like to load front panel of nested actor into root actor front panel, but not sure how to do this.
Can someone give directions?
Thanks.
(963 Views)
Presumably you want to use a subpanel. For this you need two things: the subpanel ref and the VI ref.
Decide whether you want to handle this in the root actor or the child actor and then pass the relevant reference using a message. Both ways have their merits and I would say it depends on the specific system you're building.
If it's in the root actor, send a message with the VI reference to the root (either initiated from the nested or as a reply to a request from the root) and then insert the VI.
If it's in the nested, just send it a message with the subpanel reference.
___________________
Try to take over the world!
(943 Views)
