Load values txt to a ring
Hi.
I would know how can I load the numeric values that I have saved in a txt and then load them into the values of a ring.
For example.
In the properties of the ring I want the item to be displayed as LOW, MEDIUM and HIGH is what the user will choose.
In each option the value is for example
LOW: 1.2
MEDIUM: 2
HIGH 2.6
These values are stored in a txt. and can be modified.
How I can do so that when the user choose LOW, MEDIUM or HIGH load the appropriate value?
Attachment files
Thanks.
(4,028 Views)
Steve Bird
Culverson.com
LinkedIn
(4,020 Views)
Hi Steve.
I have clear and put a ring items.
But I want to put the values loaded from a txt.
Thanks.
(3,980 Views)
(3,978 Views)
Hi alberto,
you need to create an array of clusters to fit the datatype needed by that property node.
Just open (and read) the context help to know what you need to create!
(3,968 Views)
Hi GerW
Could you give me an example or guide me a little?
I took a long time stuck at this point and I do not know how to continue.
best regards
(3,956 Views)
Hi alberto,
you need to create an array of cluster of [String, value]:
(3,945 Views)
