08-17-2020 04:11 AM
Hi All,
I'm trying to load a .STL file onto the 3D picture control. The entire model is not getting displayed. It is like there is a screen inside the 3D Picture control and everything behind that screen seems to be hidden. I have attached a screen recording so that you can understand better.
I have tried the camera position, target position and up direction properties, nothing seems to be helping. I have attached a vi that simply loads the model and also the STL file that I was trying load. Please help me understand the working.
Thanks in advance,
Dhinesh
Solved! Go to Solution.
08-17-2020 05:44 PM
Hi, @A_Dhinesh,
I don't see any attached screen recording or attached vi, so I'm not sure what you mean.
But you might compare what you're trying with the links in this post.
(Since you're already using .STL files, you've probably seen some or all of those links, whether from the post I linked or not. But hopefully in reviewing the links, you can see what changes may need to happen to make it work.)
Good luck!
-joeorbob
08-17-2020 08:29 PM
I'm trying to attach the files again here.
Dhinesh
08-18-2020 01:55 PM
Dhinesh
So, I have not yet looked at your video or tried with your particular model (I tend to be cautious about downloading files), but I opened your VI and tried loading an example .STL file in. Everything seems to work just fine.
(I did add a while loop to make it more like the snippets in this Knowledge article, and once I did, I was able to manipulate the 3D picture just fine.)
So (except for maybe adding a while loop), your VI seems OK.
Can you verify that the .STL file is good/valid?
-joeorbob
08-18-2020 09:00 PM
The STL that I have attached inside a zip file is valid. I'm able to open it properly in windows 3D Viewer or Print 3D applications that is available by default in windows.
Dhinesh.
08-19-2020 12:38 AM
There are numerical limits to the maximum dimensions of objects the 3D picture can display - you might need to scale down the dimensions?
08-19-2020 12:53 AM - edited 08-19-2020 12:55 AM
Is there any way to change those numeric limits for maximum dimensions?
I have to do some interpolation operations to add few more objects and overlays.
For Example,
I have an airplane model of wing span 30m and sensor cable of 1mm diameter and 13m length.
So, I will not be able to scale down the object.
08-19-2020 01:40 AM
I think you should try just dividing everything by 10, and see if that works.
08-19-2020 04:37 AM
Loading the STL file after scaling down is working fine. But I need the models to be in actual scale for my interpolation algorithm to work. So, I'm looking for a solution to load the models in actual scale.
08-19-2020 06:37 AM
If you don't want to scale the STL file and only want to display it in LabVIEW you could scale it there.
I can't open your vi now but this works.
