Loading *.llb first loads to folder view
When I first load a llb file it doesn�t go directly to the top level vi. What I get is windows explorer view with all the sub routines which then I have to select the appropriate top level vi. I was able to load directly by setting the top vi in Labview 6.1 but I don�t seem to be able to find a solution for labview 7.0
Cheers,
Mark
(2,915 Views)
You've have turned on Enable Windows Explorer for LLB Files. This setting is on the Options>New and Changed in 7.0 or Options>Miscellaneous page. Uncheck it and restart Windows to get the old behavior.
(2,915 Views)
that is great I have never seen that menu...thanks again!
(2,915 Views)
