Loading multiples VIs in the same window
I need to display data on two VIs. The example in the manual loads the second VI in a new a window
Is it possible to view the second VI  in the same window? The user being able to switch between VIs using a button.
thanks
(3,138 Views)
It is not entirely clear what you want, but have a look at subpanels.
(3,131 Views)
I'm confused as well. Besides subpanels, you might just need a tab control.
(3,124 Views)
