Loading .net dll files to LabVIEW
Hi All,
I'm trying to load a dll file built in .net framework v4.0.30319 of a instrument in LabVIEW using constructor node but i'm getting this error attached below. I tried with the following links
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LDcSAM&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019L3hSAE&l=en-US
But i couldnt sort the problem.. please help me..
Brijnesh JK
(3,341 Views)
Is your LabVIEW 32 bit or 64 bit? And are you on a 32 bit operating system or on a 64 bit operating system?
You seem to be trying to load a 32-bit .dll and I believe that would require a 32-bit LabVIEW.  At least this would be the first test before further debugging...
-DP
BatchTest Corp.
NI Alliance Partner
New Controls & Indicators made using vector graphics & animations? Click below for Pebbles UI
(3,317 Views)
Thanks for the reply.
I used 32bit LabVIEW 2011 edition, OS is w7 32 bit and tried to load 32bit .dll file using constructor node. Still i'm getting the same error.
Please help
Brijnesh JK
(3,312 Views)
