Local Data Storage in Objects
I have been trying to program more in Objects.  i.e. Data and Functions are bundled together in a Class or in a project library.  I have used FGV a lot in the past.  One of the things I like about a FGV is the ability to locally store data in an uninitialized shift regester.  Only the cases in the FGV can access the locally stored data.
Is there an equivilant storage method using Project Libraries or Classes?  Is it even a good idea to have locally stored data?
Dan Shangraw, P.E.
(3,705 Views)
With classes, you create methods to access the desired data.  You just need to pass around the object and call the right method to do what you want.
(3,691 Views)
Is there a way to store that object data within the object?  Do I have to pass it around in my calling application?
Does that make any sense?
Dan Shangraw, P.E.
(3,689 Views)
Hi Dan,
object data is stored within the object! Only methods of that class can access that data - similar as your FGV: only cases within the FGV can access the data in the shift register(s)!
You have to pass the object to access the data within…
(3,678 Views)
That's what that Private Class Data control is for. Smiley Wink
(3,675 Views)
