Local/Global/something else?
This question quite rightly shouts �beginner� (but we have all got to start somewhere)
Background info � (Using LCR 4284) trying to create a stepped voltage using just the DC source. So inputs accordingly are start voltage, step voltage, hold period and stop voltage.
Obviously take start voltage, add the step voltage hold for a period of time then increment again.
My problem is with the �new voltage� typically I would have just created a loop based loosely on the pseudo code below
Start voltage + step voltage = x
If ( x does not = stop voltage) then
x + step voltage
hold for period of time
else stop
tried looking at local/global variables to create a variable (x) but nothing seemed to operate in the way I expected it
Or would a shift register be better?
Well thank you for any time you spend answering this query
David Green
(3,126 Views)
Try this. It Helps?
ian"
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,126 Views)
the attatchment looks as though it is the solution to my problem and maybe other peoples problems, but i am getting an error code (8- file permission error, cannot load vi resource).
Coments from anyone else?
David
(3,126 Views)
It was created in LV6i. I have saved a copy of previous version and have it sent to your email. Check it out. Hope it is ok now.
Ian F
依恩与LabVIEW
(3,126 Views)
David Green wrote:
> This question quite rightly shouts 'beginner' (but we have all got to
> start somewhere)
> Background info - (Using LCR 4284) trying to create a stepped voltage
> My problem is with the 'new voltage' typically I would have just
> x + step voltage
> else stop
e way I expected it.
> David Green
Instead of adding the step voltage at each point, you could use
x=Start+i*Step
and put it in a for loop structure.
Remove "spamkill." when replying to this message
(3,126 Views)
