Local Security Authority LabView 2024 Q3
El mensaje indica que Windows ha bloqueado la carga del módulo nimdnsNSP.dll, que pertenece a National Instruments y está relacionado con el servicio mDNS Responder.
Si tienes privilegios de administrador, abre Símbolo del sistema (cmd) como administrador y usa:
regsvr32 "C:\Program Files\National Instruments\Shared\mDNS Responder\nimdnsNSP.dll"
Esto intentará registrar la DLL nuevamente en el sistema.
Asegúrate que el archivo se encuentre en esta ruta, de lo contrario debes poner la ruta correcta en el (cmd)
Message 41 of 85
(5,874 Views)
Apparently the 2025 Q1 version of LV does not fixe the issue. It's surprising that NI hasn't solved this issue  with Win11 in the last year! For my part, I simply checked the "don't show this message again" box.
Message 42 of 85
(5,777 Views)
I hope when they do put out a fix it isn't just for the latest version. It should be for all versions because I'm running LV2021 on Win 11. Or at least versions supported on Win 11.
Message 43 of 85
(5,763 Views)
This is a worry of mine also.
Some of us with active SSP’s still have lots of customers around the globe using legacy code from older versions of LV. These deployments need patches, too.
fact that customers can
http://www.medicollector.com
Message 44 of 85
(5,756 Views)
I'm curious... is this workaround (selecting 'don't show again') not working for some of you on this thread?
Message 45 of 85
(5,735 Views)
Yes, that is a workaround.  But I have hundreds of customers around the globe.  When they get this warning message, its bad for business.  It leads people to suspect that our software is malicious.
Message 46 of 85
(5,722 Views)
From what I recall, it did not work. It kept coming back... just like that cat.
Former Certified LabVIEW Developer (CLD)
Message 47 of 85
(5,709 Views)
With our LabWindows 2017, it does indeed come back "the very next day."
Initially, I reported it to our IT group, thinking it was something potentially malicious.
Message 48 of 85
(5,520 Views)
I know this is a serious problem, but several recent responders obviously know the song "The Bug Came Back", whose chorus goes ---
   The Bug Came Back,
   the very next day --
   We thought it was a goner
   but the Bug Came Back
   and it would not stay awayyyy.
(with apologies to G.K.)
Bob Schor
Message 49 of 85
(5,498 Views)
When you build an installer you can choose to not include mDNS Responder....
I erroneously expected that to be the easiest workaround as we do not really need it for anything in our applications.The problem though is that the mDNS Responder service still gets installed 😫 . It is not listed as a component under NI Software in programs and Features, but it shows up as an installed service.
The culprit that causes this to happen in our case is the need to install the VISA RunTime. If we remove that, no mDNS Responder is installed. So for those that do not need that, you may have a solution for the DLL error...
PS.
I had not really noticed before that if you install an application built in LabVIEW on a 100% clean machine and then uninstall it, it will not uninstall the support components that came with it, even if there are no other applications depending on them. To get rid of the support files you manually have to find the NI Software entry under Programs and Features and uninstall all those too. At the very least there should be a dialog when you uninstall a or the last LabVIEW-built application asking the user whether to uninstall them as well.
Message 50 of 85
(4,782 Views)
