Locate chirps on signal LABVIEW
I need find two chirps in attached file signal using labview. Using Hilbert transform or Gabor. You can use a intensity Graf to indicate two chirps. It is necessary use a filter too Maybe a Smoothing filter. How can help me? is a challenge!!!
(2,470 Views)
Please take a look in the following example:
http://decibel.ni.com/content/docs/DOC-9773
Thanks.
Best Regards
Luciano Borges
Test Development Engineer
(2,399 Views)
