Locate local maximum
Hi
I plot index versus value of an array with an graph. But how do I locate
index's of local maximum's of my array ?
Can I use 'wavefor peak detection' vi ? if so how ?
/ Peter
(6,020 Views)
"none" wrote in message
news:b0h0n9$142i$1@news.net.uni-c.dk...
> Hi
> / Peter
use FUNCTIONS > ARRAY > ARRAY MIN&MAX
Ale
(6,020 Views)
The question was about LOCAL maximum.
(4,973 Views)
First of all, the question was 15 years old.
The question was not very clear because it did not define what is meant by "local". If the data is very noisy, every other point is a local maximum.
Obviously, you seem to have a similar problem. did you solve it? Are you trying to find locations where both adjacent values are higher? What kind of threshold defines a local max if all values are quite similar?
Easiest for us to understand would be if you could attach a simplified VI containing typical data. Then tell us which locations you are trying to find. Is there a natural width to the features of the data? Yes, the peak detector could be of help if tuned correctly.
(4,931 Views)
