Locate "DAQmx Read (Analog 1D Wfm NChan NSamp).vi"
I'm a new user to LabVIEW, and trying to get up to speed. I have a legacy project that was written in LabVIEW that makes use of several hundred .vi's. This project SHOULD have been complete with all necessary libraries, etc., but that is proving not to be the case. Some of the virtual instrument files were found in the "standard" NI libraries, some were from the OpenG libary, etc. But one I can't seem to locate anywhere: DAQmx Read (Analog 1D Wfm NChan NSamp).vi
I see many references to it (and errors it can cause) in these forums, but I can't seem to locate where to go to actually download it. Any help would be appreciated.
Thanks!
(2,868 Views)
What version of LabVIEW and DAQmx are you using? Did you install DAQmx after LabVIEW?
(2,866 Views)
Dennis: thanks so much for the reply. Installing DAQmx would be a good start. I wasn't even aware it was something that had to be installed separately! Downloading now...
Thanks again!
(2,857 Views)
