Locate "NI_DAQmx 9.4" media path
I am attempting to add the NI-DAQmx MAX Configuration Support 9.4 into an application isntaller package. I use a network install of LabVIEW and that means I do not have the CD's that the installer seems to be asking for. Being the case I downloaded the NI-DAXmz 9.4 installer from NI.com to my local machine and unzipped the package and have the installer pointed to that folder.
I get a very annoying error message that gives no indication of how to fix it.
What more does it want? How do I fix it?
(2,739 Views)
Hi bconway6,
Did you try to install the DAQmx 9.4 driver that was downloaded onto the machine that will deploy the application? First uninstall the current version of the DAQmx drivers on the deployment machine and then install the new download.
Milan
(2,714 Views)
