Locating source file NAME from the executable file?
@crossrulz wrote:
For a simple SCC software, take a look at Tortoise SVN.
I suspect if you did a Web search on LabVIEW SVN, you would find a number of hits and articles about "How To" use Tortoise SVN with LabVIEW.  I'm old-fashioned -- I have not used any of the add-in Tools that give you right-click access to SVN from within LabVIEW.  However, I do use TSVN all the time when developing in LabVIEW, and it has saved my rear end on numerous occasions.  It is also wonderful when you work from multiple sites, as you can always be sure of getting the "latest version" (provided you remember to Commit).  Confession -- before using TSVN, I used to save things on Flash Drives (I almost said "floppies"), sometimes with a date, sometimes without, and keeping track (and remembering to unplug the floppy and carry it back to work) was not pretty.
BS
Message 11 of 11
(804 Views)
