Locating the position of the brightest pixel in a region of interest
I need to locate the x and y coordinates for the brightest pixel in a region of interest rectangle (user defined).  I see that there's a Light Meter that uses a rectangle, but I can't find a way to have it tell me the location of the brightest pixel (only the intensity)
Any input would be appreciated.  I'm using v7.1.
(2,577 Views)
I don't have time to try to come up with a solution that uses divide and find.  Divide in for sections, find the brightest one, then divide that one into four sections.  Keep going until you get your answer.
If you use IMAQ Light Meter (Line) you can find the pixel using the line profile.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,562 Views)
