You must use Windows 2K or XP. Put your Labview app in unique directory. Create a unique user name and password using User Manager. Use permissions to restrict the new user name to allow read/write/execute to the Labview app directory, and do not allow anything to other directories. You will have to change permissions on every other directory so as to remove "everyone" from accessing. When the user logs in, he will not be able to access anything except whatever is in the LV directory.
