Lock windows folder from labview
I want to lock a windows folder with password from LabVIEW 2017. Is there any inbuilt funtions in labview to do that.
(3,133 Views)
The simple answer is "No, there is no Lock Windows Folder with Password from LabVIEW 2017".  I also have no idea what you are trying to do -- are you trying to prevent LabVIEW from reading a file?  Are you trying to allow only LabVIEW to read the file?
Bob Schor
(3,108 Views)
hi rakesh,
i don't think there is a function for that,
but you can use the "System Exec.vi"
have a look at these two links
https://www.computerhope.com/issues/ch000705.htm
https://www.youtube.com/watch?v=IJNXcto20SQ
in a similar fashion, you could also use any other external program that is controllable via the command prompt.
regards
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,107 Views)
