Locked library not included in executable
I have taken a small subsection of code from a much larger VI I use to evaluate Bit Error Rates on an tester.
This small section of code I wanted to use to create a simple executable that the technicians could use on the test bench when manually retesting receiver failures.
I'm new to creating executables.
From the vi, I do "Build Application (EXE) from VI" from which a project is created and then "Build".
In my local "build" directory, I end up with a folder and several files (.exe, .alias, .ini and a dll).
In the meantime, I have the latest LV Runtime engine installed on the testbench PC.
I copy this "build" folder to the test PC and when I launch the executable, I get errors because it can't open a "Spline Interpolation" library file.
The file is located within the project that was created, but it shows it as being "locked".
Am I doing something wrong here or is this "analysis" library exclusive to the PC where LabView is installed?
Peter
(3,261 Views)
I forgot to add, that I am running LV 2011 Full Development System.
I seems to me that this Interpolation vi is located under  "Professional Package Advanced Analysis"
Maybe I don't have the rights to use this VI away from my development PC?
(3,257 Views)
Did you install the std runtime engine? Maybe you only installed the minimum version on the target pc?
(3,250 Views)
Accepted by topic author sdp54321
I had LabView Runtime 2011 v11.0.320.0
I'm not sure what it is... min or std
So I uninstalled it and reinstalled LVRTE2011f3std.exe
Works great now.
Peter
(3,225 Views)
