Locking the diagram window
Hello all...
Can someone tell me how I can lock the diagram window so
no one can see the logic of the VI without my permission?
Tom
(3,383 Views)
Under the File menu, Use Save with options. Select Apply new password.
Tom Impelluso wrote:
> Hello all...
> Thanks,
> Tom
(3,383 Views)
two options here...both can be accomplished using Save with
options... under the File Menu. In the Selected Options box you can
password protect the diagram or there is also a 'remove diaqrams'
option.
Use caution tho, there is NO WAY to retrieve the diagram from a vi
that is saved this way, so if you use 'remove diagrams', save a copy
elsewhere that includes the diagram. elsewise, its in the wind...
HTH
Rick
In article <38AEDF00.74872874@kahuna.sdsu.edu>,
impellus@kahuna.sdsu.edu wrote:
> Hello all...
> Thanks,
> Tom
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,383 Views)
Select
Project> Vi info >Passwordprotected
Click here for Free Video!!
http://www.gohip.com/freevideo/
Tom Impelluso wrote in message
news:38AEDF00.74872874@kahuna.sdsu.edu...
> Hello all...
> Thanks,
> Tom
(3,383 Views)
