Log 2 voltages simultaneously
hello Joeri,
Normally you should be able to use an XY Graph to do this kind of plotting.
Have you installed the DAQmx driver?
If yes, then make sure you also have installed support for LabVIEW 2010.
If you want to use a VI made in LabVIEW 2011 on a LabVIEW 2010 system, then you should save it for a previous version on your LabVIEW 2011 Development system.
If you don't have access to such a set-up, then I can also do this for you.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 13
(708 Views)
Hi Thierry,
Yes I've figured that out now 😄
No I don't have it installed yet, does it come with the usb-6009?
I haven't ordered that yet so I guess I can't really get started on my program?
Right now I don't have access to a 2011 system. I've attached the program I think will help me out.
I've also attached the program (Eindwerk.vi) I've made so far, not too much progress but anyway it's something.
Thanks for al your support!
Message 12 of 13
(695 Views)
Hello Joeri,
I've added your files to a project (always a good idea) and converted them to 2010.
There however does seem to be a VI missing. (you'll see it yourself when you open it.
The latest version of the DAQmx driver can be downloaded from over here:
http://joule.ni.com/nidu/cds/view/p/id/3811/lang/nl
Kind Regards,
Message 13 of 13
(691 Views)
