Log GPS time, position, velocity
I'm using the read gps time, position, velocity.vi and now I want to log this data in a text or spreadsheet file. Is there a simple way to do this? I tried with write to measurement file, but this only handles dynamic data and no string or time stamp.
(3,776 Views)
(3,766 Views)
I've read the help of the write to spreadsheet VI but I don't understand how I can read in multiple information and get them in separate columns. Here is the block diagram of what I've got till now.
My goal is to log lattitude, longitude, speed over ground, course over ground, UTC time, lattitude N/S and longitude E/W.
(3,743 Views)
Accepted by topic author Donski
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,735 Views)
a much different take, note the string constant format to anything...Smiley Surprised
(3,710 Views)
Sorry for the late reply, but thanks for the support...
(3,655 Views)
When adding a carriage return after the serial string causes the data to be shifted by a tab space located on the next row?  I've seen this with most of the file saving techniques but never posted the issue.
DG
(3,579 Views)
