Log in password protected app.
I'm looking for an example of a vi that has a user log in and password that would allow the user to change the password after some expiration date.
I found a post in the forum but it was LV7.1 and I only have 7.0.
I know I'll need to use some sort of encryption for the file, so if I could get an example of that too it would be great.
Message 1 of 8
(4,040 Views)
Is the other post something that would be adaptable for your purposes?  There would likely be very little difference between a VI built in 7.1 and one done in 7.0.  I did a quick search of "encryption" here in the forums and found quite a few posts on the topic.  I would think that you'd be able to piece something together pretty well by using what's already out there.
Peter
Peter L.
www.ni.com/support/
Message 2 of 8
(3,999 Views)
Peter,
I beleive that the vi in 7.1 would be fine the problem is that I can't open them. Is there a way to view LV7.1 vi using 7.0?
As far as the encryption, I will search the forum.
Jeff
Message 3 of 8
(3,991 Views)
If you post either a link to the thread where you found the 7.1 vi or the vi itself, I'm sure someone would be happy to save it to 7 for you.
Message 4 of 8
(3,986 Views)
Duh! Thanks, I don't know what I was thinking.
If some one could save these vi's to LV 7.0 I would appreciate it.
There are six vi's altogether.
Thanks.
Message 5 of 8
(3,970 Views)
Message 6 of 8
(3,967 Views)
Thanks.
Here's the LV 7.0 version:
Message 7 of 8
(3,955 Views)
Thanks to all.
Message 8 of 8
(3,938 Views)
