Log in
HI here is my question
I have a VI of a Log-in , and I want to put
an option where you can add a new user, but a don't know how
to save the new user and password on a table that a made on access
can someone help me?
Message 1 of 11
(6,387 Views)
well you can use Activex or if you have the database connectivity toolkit you can use it to connect to Access and save your data
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 11
(6,378 Views)
Ya thats true you have to make creat table in data base or exel.
Let me alobarate in brief. There are lot many other ways but simple one is
Creat new vi say name it add user.vi
You creat a table say User details. on Front panel.
Column name Username , User level ( If you have) , Password.
This table you can save into the database as well as into the binary file So that others cant view.
Creat a string control User name and two string control for password repeatablity check. and userlevel if you want (admin, sup, operator)
Creat two button name Add user and  Cancle ( Or close window you can use).
On add User Event "check both password are same" and "user already there",  Then you can add user name, User level , password into the table.
Thats it.
This table you can use in Login.vi
Read this table for login vi.
CLAD
Labiew programmer
Message 3 of 11
(6,359 Views)
I didnt understand exactly what you say, but i made it using sql code to write user and password to the access table 🙂
Thats it.
How can I check if the user is already  there?.
Message 4 of 11
(6,332 Views)
Select <username> from <namecolumn>
If you get a value back, it's there.
There may be a better way, I haven't used DB queries too much.
If you want to add it if it doesn't exist already, have a look at this article
http://dev.mysql.com/doc/refman/5.0/en/insert-on-duplicate.html
Message 5 of 11
(6,327 Views)
Message 6 of 11
(6,321 Views)
Hey thanks, I try some examples but didnt function, but thanks anyway. 😄
Message 7 of 11
(6,312 Views)
At this point you should really post your code and your access database for people to help you figure out what's going on.
Message 8 of 11
(6,305 Views)
Well here's the block diagram, someone gave me a code on SQL
but I don't know were to put it, he said that on  ADO
But don't know what ADO, and how  to use it
*****************code **********************
"select * from login where usuario='" & txtusuario & "' and contrasena='"
& txtcontrasena & "'"
if adodc1.recordcount>0 then
msgbox "User and password repeated"
else
'add values
end if
Message 9 of 11
(6,295 Views)
You have not posted your code. You posted an image which cannot be debugged. You would also need to post those SQL functions. Those are not from the NI toolkit or the commonly used LabSQL toolkit.
Message 10 of 11
(6,266 Views)
