Logarithmic Binning Histogram
I want to plot the logarithmic binning histogram of a 1D array in LabView.
It means the x-scale is logarithmic and the bins are equally spaced in log10.
I have done it in python and I'm using this Python function in LabView to plot logarithmic binning. But it is not efficient and I want to do it in LabView.
Python function:
import numpy as np
import matplotlib.pyplot as plt
def f(data_array):
      mini=min(data_array)
      maxi=max(data_array)
      bins=np.logspace(np.log10(mini), np.log10(maxi), 80)
      widths=(bins[1:] - bins[:-1])
      n, bins, patches=plt.hist(data_array, bins, density=True)
      plt.xscale('log')
      plt.xlabel('interval times(s)')
      plt.ylabel('number')
      return plt.show()
My LabView code:
Do you have any idea how can I do that?
I can plot a histogram in LabView with Logarithmic x-scale but the bins are not logarithmic:
Message 1 of 18
(7,019 Views)
 go to graph properties. select scales tab then select X-Axis and enable log
CLD Using LabVIEW since 2013
Message 2 of 18
(7,013 Views)
Kartiknattar,
Thanks for your response, I already have done it.
As I mentioned I need the bins to be equally spaced in log10.
If I choose the interval a constant number and just choose the x-scale logarithmic, then I will have this:
This is not what I want. As you see the bins are not equal in the log scale.
Message 3 of 18
(7,006 Views)
Try this example code. It might help you..
https://forums.ni.com/t5/Example-Code/Programmatically-Set-A-Graph-Scale-To-Linear-Or-Log/ta-p/35244...
Message 4 of 18
(7,003 Views)
For example, by this simple code and choosing x-scale logarithmic but interval as a constant number:
I will have:
But with the Python code, for the same array I have:
That is what I want. So the x scale is not the problem, I should do some thing with the interval. but I dont know how.
In python I have set the bins:
so, the intervals of the bins are Logarithmic.
Message 5 of 18
(6,998 Views)
Actually, my Python code had some problems 😁, The correct one is this:
   data=[10, 10, 100, 2, 2, 10, 10, 1, 1, 100, 10, 10, 50, 50, 50, 50, 100, 100, 100]
   maxi=max(data)
   mini=min(data)
   pl.hist(data, bins=np.logspace(np.log10(mini),np.log10(maxi), 80))
   pl.gca().set_xscale("log")
   pl.show()
The result is:
So, I expect this result from LabView.
Message 6 of 18
(6,980 Views)
   maxi=max(data)
   mini=min(data)
   pl.show()
The result is:
Have we missed something? Your "Python code had some problems" so you assume the issue is with LabVIEW not Python?
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
Message 7 of 18
(6,973 Views)
The problem is that I dont want to use Python. I just want to have the bins that are equally spaced in the x scale (that is logarithmic) all in labview.
Message 8 of 18
(6,970 Views)
I mean how can I define "np.logspace" in LabView to wire it to the interval of LabView histogram.
Message 9 of 18
(6,968 Views)
@Noa_A wrote:
Kartiknattar,
Are you sure you know what you want?
The bins above are equally spaced in the log scale, as the scale goes up, so the bins get closer - and bin width and distance between the bins halves (the definition of a log scale).
Equally spaced (the same width) would not be a log scale!
Message 10 of 18
(6,962 Views)
