Logging Data using Queues
I still have some problem with storing the data.
The queues seem to work fine. However, in addition to the measured voltage in the example, I want to store another column which is let's say 5 for the whole time the code is running.
I tried to do this as in the VI posted, but I only get the 5 every now and than in the file, all other times, it's 0. This makes a little bit of sense, as I think during one loop iteration, more than one measurement value is created (?). Not sure if that is the reason..
Thanks for any hints on how to solve the issue.
Regards
Message 11 of 11
(715 Views)
