Logging Longitude and Latitude into text
I understand that LabView can save the Longitude and Latitude of the GPS into a text file. My question is how can I open the log file and put the Longitude and Latitude into column and rows of a table.
Because from there I'll do some computations.
From
Don
(2,753 Views)
Hi Don,
You can save any numerical array data to tab-delimited text file using Write To Spreadsheet File.vi from the File I/O palette. "%.6f" should be a good format string for GPS data.
You can then import the file into any spreadsheet software.
Good luck!
Zador
Message Edited by Zador on 04-24-2005 10:50 PM
(2,738 Views)
