Logging data every hour, labview stops responding when program stopped
ARG
Message 11 of 16
(1,564 Views)
Hmmm same problem. Perhaps just post a screen cap? Based on your description I assumed you moved the "Write Data [Channel Group]" express VI outside of the main while loop? I tried that and it seems to be working but I wasnt sure. If that is that case Im curious, what about that set-up causes the bug? Thank you.
Message 12 of 16
(1,559 Views)
Accepted by topic author glib
Here is LV 8.6.
I know what the problem was.  I was clicking the version of the analysis kit as LV 8.6 in the big white box, but forgetting to change the upper down to LV 8.6.
Message 13 of 16
(1,549 Views)
@Ravens Fan wrote:
Here is LV 8.6.
DOH! (Facepalm) bingo
Thanks Bill
Message 14 of 16
(1,542 Views)
I'm surprised I did it so many times in a row before seeing the problem, and that several of us had the same problem.  Yet it isn't something I hadn't done very often in the past.  Something about that dialog isn't designed very well if our attention was drawn to that box and not to the important part of the dialog which is the drop down.
Message 15 of 16
(1,534 Views)
That did it! Thanks all!
Message 16 of 16
(1,523 Views)
