Logging data into a Global variable, while execution is in parallel.
Hello all,
Can anyone give me an gist of how to Log data that's been recorded or executed, across sites running in parallel to be logged within same file.
The method that am thinking is to put a file global under, file properties - same global variable for each and every sites and logging my Data inside one global. Is there any other procedure of handling the same.
 We can't help everyone, but everyone can help someone.. Smiley Happy
Message 1 of 9
(3,987 Views)
What do you mean by "sites"?  Parallel loops in the same application?  Separate computers?
Other factors to consider:
Do you need to save all data?
Is the data to be logged at the same rate?
What file type do you want?  Raw binary?  Text?  TDMS?
But short answer: Global Variables are NOT for logging.  I inherited a project that did that and it did not work well.
Need more information before I can give better advice.
Message 2 of 9
(3,983 Views)
Sure.. pleasure explaining!!
Sites as mentioned represents; sockets running in parallel in TestStand, which is more or less similar to a parallel loop running independent of each other.
I can elaborate this further as:
  1. 2 parallel test sequence, measuring different signals that are independent.
  2. the data from both the socket is logged in a 'single' file, differentiated by socket numbers.
  3. Logging (.txt) of data will be at same rate, as the code is written for once and duplicated according to the process model (in this case, parallel process model).
  4. As an initiation of logging data in test sequence, a variable was created to store such data at execution time and project it to the data-log, palette when all sockets have finished measure_part. Am I clear.
This was also interesting, can you share knowledge about it.
Message 3 of 9
(3,927 Views)
Accepted by topic author PriyadarsiniS
In this case, I would use an Action Engine to store your log data.  This ensures the read-modify-write process is protected by having the VI itself act as a semaphore (non-reentrant VI, so only one call can run at a time).  The cases I can think of you will need are Initialize, Clear, Add, and Get.  Of course you will have an input for socket number.
Message 4 of 9
(3,923 Views)
A Look At Race Conditions
Are Global Variables Truely Evil?
Message 5 of 9
(3,920 Views)
This ensures the read-modify-write process is protected by having the VI itself act as a semaphore (non-re entrant VI, so only one call can run at a time).
But, the VI must be accessed at the same time in-order to log data whenever it's present or at the time of execution of that particular test sequence step, right.
Will not, a 2 D File global that is hard coded based upon socket numbers as column numbers to store respective sockets data serves the purpose.. even-though, its a risky method.
Let suppose this data must be processed, which storage method would be convenient to retrieve data (.txt, .csv etc.,).
Message 6 of 9
(3,907 Views)
Very risky.  You are opening yourself up to one major race condition that will make you lose data.  That's why I recommended the Action Engine as that prevents the race condition.  And the operation will be fast enough, that the parallel work will still mostly be there (about as much as things actually run in parallel purely due to CPU limits).
Personally, I like to store my data as tab delimited text or TDMS files.  Since you just have a 2D Array of numbers, I would be more tempted to go with the TDMS and make a different channel for each column.
Message 7 of 9
(3,901 Views)
That was very helpful, thank you Tim.. Smiley Happy
Actually is there any recommended site for downloading TDMS viewer, as I have already
implemented LV2G and its working fine!!
Message 8 of 9
(3,868 Views)
I am a big fan of Scout by Signal.X.  You can view the TDMS files with the free version.  If you want to edit the files and some more advanced things, then you can pay to get the Pro version.
Message 9 of 9
(3,861 Views)
