Logging off windows
When I log off Windows XP with either a LabView or LabWindows CVI application running the log off operation closes the LabView or LabWindows applications and then stops. If I then logoff again windows then shuts down. If I have several National applications running then I have to request a log for each one and an extra log off to finally close Windows. If I log off with any other application running I only need to log off once, Windows will close all the other applications and saving any data as required.
Has anyone any ideas why LabView and LabWindows behave like this or what I am doing wrong?
Steve
(4,487 Views)
It depends on how you're logging off.....
There is a "Shutdown" feature which can be called from the command prompt. Have you tried this?
Try (shutdown -s -t 60 -c "Shutting down from LabVIEW") without the ( ).  This should shut down the system with a counter set to 60 seconds and the message "Shutting down from LabVIEW".  The shutdown can be aborted by calling "shutdown -a" from the command line before the 60 seconds are up.
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(4,468 Views)
Thanks Shane,
That works well, Set up as a .bat file from an icon on the desktop it is easy for the test operators to use but is there any way to set up windows so it can log off using the standard method from the START BUTTON?
Steve
(4,436 Views)
It seems that using "shutdown -l" instead of "shutdown -s" will log off the current user rather than shutting down.
(4,426 Views)
Sorry,
as I work on a single-user PC, "logging off" was skipped over visually, and "shutting down" was registered in my brain.
As kejander said, switching the options on the "shutdown" command allows you to log off as far as I know.
Hope this helps,
Shane.
(4,403 Views)
Hi Steve,
This is a known issue - certainly with LabVIEW. In that if you have LabVIEW open when you go to the Windows 'Start>>Shutdown' it only shuts down LabVIEW but not Windows.
What version of LabVIEW do you have? This was reported with version 7.1 and has been fixed with version 8.0
Regards
Hannah
NIUK & Ireland
(4,382 Views)
Thanks Hanna
I am using LAbView 7.1 is this my justification to get an upgrade?
Steve
(4,373 Views)
