Logic with selecting a value!
I am struggling with a simple Smiley Sad logic problem!!
I have to select a letter from A, B, C, D, E, F & G.
What I want is a display on the front panel (see the figure Logic)...........and when I click any button.....it sends the corresponding letter for processing. The condition is that I want only one letter to be send at a time...(as in figure logic) and not like as in figure logic2 or logic3!!
Any idea?
Aidy
(3,868 Views)
Hi Aidy,
you can use a radio button for it.
Mike
(3,854 Views)
Accepted by topic author Aidy
Hello Mike..
A radio button is a perfect option 🙂
but........i want to select only one option at a time...........e.g If A is ON and someone clicks B.....then A should be OFF and B ON........similarly if F is clicked it should be ON and the rest OFF.
Aidy
(3,833 Views)
Aidy wrote:
Hello Mike..
Aidy
Hi Aidy,
see the attached example.
Mike
(3,826 Views)
Yes ie works 🙂
Thanks a Million Mike Smiley Very Happy
Aidy
(3,814 Views)
