Long term countdown timer
First, "borrowal" is not a word.
Second, doesn't Bowen's message give you a clue what to to?
Whenever the current time is greater than the due date, then the boolean is true.
Message 11 of 33
(3,525 Views)
Hello
i did implement what you told me.but i am getting an error
because i have to connect the updated status to the concatenate string as shown in the string
Message 12 of 33
(3,521 Views)
@ Raven
I did implement it
but i am having error
Message 13 of 33
(3,516 Views)
Well think about it.  You are trying to concatenate a Boolean data type to a string.  What do you want to be placed in that string when the Boolean is True?  What do you want to be placed in there when the Boolean is False?
Message 14 of 33
(3,510 Views)
i didnt want to key in manually if the latter return it or not on time..
i wanted it to be autogenerate automatically.
when the boolean is true: the date is exceeded and there ( is a notif (Misplaced) or led light up) representing that it is exceeding the limit of returning the equipment.
when it is false, it shall written Ok as the status
yeah concatenate this information so that i can store it in my database which i did with excel
Message 15 of 33
(3,504 Views)
Then you will need to wire the boolean to a Select function that will return "Missing"  (or whatever) if True and "OK" if false.
Your manipulation of the date/time record cluster is not what BowenM showed you in is example.  Why did you change that?
Message 16 of 33
(3,499 Views)
Yes sir, what Mr BowenM show me is that the date is constant, but me i wanted to get the data autogenerate also. like i did
in my VI, i add 7 days.
But when i am trying to implement say thing for the time. I am unable
correct me if i am wrong
Message 17 of 33
(3,489 Views)
sir i try to redo it
n follow what you told me and Mr BowenM says
This is what i am getting. Even though i am trying to connect it to the concatenate string, i am getting
error
Message 18 of 33
(3,481 Views)
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Figuring out why wires are broken is a basic LabVIEW skill.  Hover over the wire with Context Help turned on will tell you why that wire is broken.
Spoiler
You've got two sources.
Bowen showed you when current time - checkout time is greater than 7 days, you are overdue.
You proceeded to program when Current time + 7 days - Current time is >= 7 days, you are overdue, but complicated it further by converted time to the date/time cluster than back again.
Message 19 of 33
(3,478 Views)
thank u very much
i will try it and check it out
thanks for helping
Message 20 of 33
(3,466 Views)
