Look out for a method to present a list of array elements on front panel while allow the user to change and save the list after modification
I have a list of items imported from an excel file and stored in an array in LabView. I intend to present them on front panel using a list. The user is capable to edit the list (remained or removed the row) and save the change afterwards. However, I’m not sure which front panel object in the List, Table & Tree palette could work for this purpose. Any recommendation? Or, is there a better way than using a list?
(2,885 Views)
Accepted by topic author Jenjen
Hi Jen,
I recommend to use a ListBox, especially as you want to work with full rows:
- you can easily react on user actions in the ListBox with an event structure
- the user can select multiple rows at need (when you enable this option)
- you can have row titles
- you can format each column (or even cell) as needed/suitable
(2,875 Views)
