Looking for DaqMX 8.8
I have been trying in vain to find a download for DaqMX 8.8
Online versions stop at 9.0 and the old ftp server only has up to 8.6 that I can find.
Can anyone direct me to a source?
(1,281 Views)
Why does it have to be exactly 8.8? Maybe this would be an option if you specifically require that version.
Rolf Kalbermatter  My Blog
(1,256 Views)
Thank you for the link Rolf.
It likely doesn't have to be exactly that version, but a tangled mess of logistical hurdles leads me to believe it's the quickest solution at the moment.
Trying to support an old system where a real time target had to be reimaged.  It's an old desktop, circa 2014 with the image installed having DaqMX 8.8.  Windows machine has 8.6, but I am unable to push tasks or even bump the version of MX up or down through MAX with an error code noting the software version mismatch.  Unfortunately, I am doing this remotely from a different country while instructing folks who are unfamiliar with the process.  So hoping that installing 8.8 on the Windows machine side is the simplest solution in the short term until I can go onsite and sort it out.
(1,235 Views)
