Looking for VI for PNI MicroMAG3
I am having difficulty wiriting instructions to a PNI MicroMag3, 3 Axis Magnetromoter. A 8 Bit instruction must be sent during the first 8 clock cycles and then the Sensor should return a 8 bit value for the next 8 clocks. The Inital Instruction tell the sensot which axis to return data for.
I am using the USB 8451.
Would anybody have a VI that communicates with this sensor or could they advise how I can send the inital 8 bit instruction throuch the SPI connection.
The Data sheet is attached for the sensor.
All the best.
Gus
(4,063 Views)
Here is the VI were are using to communicate to the Magnetromoter. I cant seem to get the sensor to return the data. After the first 8 clocks it should start to shift out the reading.
Great is someone could have a look.
Rgs
Ben
(4,037 Views)
Hey Ben,
I can't look at your code now (can't download it while I am at work), so instead I am going to ask some stupid questions.
1) Did you check the clock polarity and phase (settable on the 8451)?
2) I've used the 8451 but it's been a couple of months... I think if you are trying to read from it, you need to write a byte, then read a byte....
I'll look up my code when I get home and see if I can remember the procedure.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(4,018 Views)
Hi.
I have a solution to this if anyone requires it contact me.
Rgs
(3,862 Views)
All the best.
Gus
Hi Creg, please can you help me with PNI Magnetometer - USB-8451 communication ? Any working vi code ? Thanks
(3,692 Views)
FYI - Main part should be working. The compas might need extra VI's there onthe web somewhere.
(3,675 Views)
Thank you Creg
Best Regards
John
(3,663 Views)
