Looking for Vision 7.1.1 runtime engine
I have a vision application that has always been used on the development machine. Now I need to deploy it.
It's written in LabVIEW 7.1.1 maintainence release, with Vision development 7.1.1. I can't go newer on the development environment as the target machine is Win NT.
The application supports a linescan camera - allows adjustment, captures image, saves to disk.
I have a deployment license and deployment engine CD , version 7.0, so I need an update to 7.1.1.
I can't find it anywhere. Downloads available on NI.com jump from 7.0.1 to 8.0
I have searched the forumes for the answer without luck. Does anyone have any pointers?
Cheers.
Bandit
Message 1 of 8
(4,391 Views)
You can find all versions here.
Message 2 of 8
(4,375 Views)
Thanks smercurio_fc, it's actually here (as it's the vision engine I needed) but I wouldn't have found it without your guidance.
(and I learned how to add a hyperlink too. Excellent start to a Monday morning. it's all downhill from here I guess!) Smiley Very Happy
Bandit
Message 3 of 8
(4,359 Views)
Didn't learn how to turn bold off though...  doh.
Message 4 of 8
(4,356 Views)
  just to tidy this up for others on the forum,
The Vision Run Time Engine for 7.1.1 was part of the Vision Deployment Engine and was a purchasable part, so not available for download.
If you require this, then we need to check with your internal sales engineer with regards to entitlement etc, and then we can burn the cd.
For each deployment of your Vision applications that uses this Run Time Engine you need to purchase a license, as the Run Time Engine for Vision is not freely distributable in the same was as the LabVIEW one is.
We've already spoken to "Bandit" and resolved this so a CD is on the way.
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
Message 5 of 8
(4,345 Views)
Sorry about that - misunderstood your question. Glad you found what you were looking for in the end.
Message 6 of 8
(4,334 Views)
That's OK, my original question could have been clearer.
Bandit
Message 7 of 8
(4,330 Views)
CD received. Still got some problems with my application - but that's for another post. Thanks for prompt delivery to those involved at NI.
Bandit
Message 8 of 8
(4,310 Views)
