Looking for an inexpensive way to raise and lower a breadboard with LabVIEW
I have a breadboard that weighs approximately 50 lbs and i need to raise and lower it around 25 mm. I would like recommendations for the good low profile lifters (stages, scissor jacks, actuators) that are simple and do not require expensive controllers. Just need to be controlled with LabVIEW
Hardware i have: CRIO 9056
(1,000 Views)
Since you have a CRIO, do you have an unused slot?  A NI-9472 module could be used for the LabVIEW control, and then you just need to find any sort of actuator that can be raised/lowered with a digital output signal, and not restrict yourself to something that has a control input designed for PCs.
The 9472 is just the cheapest one I saw, but there are many other modules that also do digital out that you could use also if you want other options, such as being able to use some of the lines as sensor inputs or to have different output levels, or to use relays instead of sourcing outputs.
(952 Views)
