Looking for driver with "HP E1326/1411 *.vi
does someone know in which driver file the following vi´s are:
HP E1326/1411 Data Avail Query.vi
HP E1326/1411 Read Mult Meas.vi
HP E1326/1411 Config.vi
HP E1326/1411 Trigger Setup.vi
HP E1326/1411 Arm.vi
I tried the 1411-Vxipnp-file and 1326-Vxi-pnp-file. After installing them i
created the llb in Labview with "Importcvi Instrument Driver", but the vis i
need are not in there.
Is there a driver file which supports both instruments oder where do they
come from?
Thx
(3,047 Views)
I looked at the LabVIEW driver (which I would recomend you use instead of the CVI one) as well and could not find the exact same names in there either. It's likely that the driver has undergone some revisions over the years. The last rev is fairly recent but I have no way of knowing when the change occured. Unless someone from NI can pull something from the archive, you may have to use the new functions which from the names at least, do seem to about the same thing.
(3,047 Views)
In which driver did you look? I found out, that in the 1326-driver-file
(which can be downloaded from ne ni-homepage) the function-name are looking
like the ones i need. Alle the functions in the driver are also beginning
with "HP E1326/1411........vi" but the 5 functions i need are not in there.
Is there a CD from NI where i can find alle the drivers or where did YOU
look?
Thx
(3,047 Views)
Instrument Driver Network. This has all of the current drivers, including the LabVIEW one for your instrument.
(3,047 Views)
Hi Powder,
The driver you are looking for is on Instrument Driver Network. Type "hpe1411a" in the Additional Keywords field and download the LabVIEW driver for this instrument.
I hope this helps.
Vesna
(3,047 Views)
> The driver you are looking for is on...
> Vesna
That´s the one i was looking for.
10000 times thanks.
(3,047 Views)
