Looking for missing component for NISCOPE
I downloaded NISCOPE installation file(niscope.exe). When I tried to install it, I got an error message saying “Missing Component Scope-SFP 1.1f2”. Where can I find this component?
(3,194 Views)
Ahmet,
I would recommend downloading it again, or requesting the CD from NI.
I have had so much difficulty downloading from NI in the past (especially NI DAQ) that I gave up.
Good luck
(3,194 Views)
You can find the NI-SCOPE Soft Front panel on the National Instruments website at www.ni.com then follow the following links:
-Under Technical support "Downloads"
--"Drivers and Updates"
---"Current Software Versions"
----"Scope Soft Front Panel"
(3,194 Views)
I followed the instructions you provided, and the problem has been solved.
Ahmet.
(3,194 Views)
