Looking for on line datalogging of Hydraulic crimmping by acoustic sensor
Am a solution provider for m/c tool manufacturers and am looking for a datalogging H/W & S/W for acoustic measurement at the time of components failure, if at all occurs.
The db range max. 80 to be as per the m/c std.
We can dedicate a PC for this purpose.
Kindly suggest that this is a most important parameter to be measured & solution is a must to make m/c complete.
(2,704 Views)
Can you give your specifications in a bit more detail.
Seems that you are from India. You can call 08041190000 to connect to NI India personnel who would be able provide you with your HW and SW requirements.
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(2,684 Views)
I would talk to someone from Kistler Instruments. http://www.kistler.com/
They have a ton of unique sensors for this type of application.
(2,673 Views)
