Looking for serial instrument drivers for MKS 647B (mass flow controller), MKS PR4000 (pressure gauge controller) and Granville-Phillips 358 (pressure gauge controller).
If anyone has anything that will talk to these instruments serially, I would be ecstatic. They're relatively simple, but I figured I'd try to see if it's been done already.
-Jake Stern
jake@flexics.com
(3,301 Views)
For the 647B try using the analog inputs and skip the serial interface altogether. Send it a voltage from one of your analog outputs corisponding to the amount of gas you want. Far simpler than traying to talk to the thing. good luck...
(3,301 Views)
for this type controller i have 2 ch. 12 bit adc board with 16 digital output that work on serial port. you can aquir analog data from eny instruments and can controls 16 relay on serial port with labview. if you want circuit diadrams for it i can help you.
Rajendra Singh
loadcell@sify.com
(3,302 Views)
I downloaded the driver for PR4000 somewhere on the internet, If you need it, I'll e-mail you.
It is not a good driver anyway!
Let me know.
P.S. I am not able to "swith on" or enable the mass flow controllers, but I must press the "ON" button on the front panel. do you know which command do I have to send?
(3,063 Views)
